gumleguf
gumleguf's Avatar
02.07.2012, 04:32 AM
Jamie did say he would allow it to accomodate the wider packs, but later in a phone conversation explained that in order to use wider packs, you need to trim the inside leg on the included stops, thereby using the chassis braces as the inner battery stop - not the most elegant solution I guess and not the initial plan as explained, but a workable solution.
There are instructions included in the kit about trimming the stops. At least there was in mine. But I don't bother, I'll use velcro straps insted.
