aqwut
Brushless Heavy Weight....
aqwut's Avatar
02.16.2012, 11:47 PM
I had to remove a water cooling jacket off of a 2280, and it was "HELL". I drilled a hole on a 1/4" plate of steel, and drilled another 10mm hole on another 1/4" plate of steel. Then I used 2 big "C" clamps to remove. (Do it very slowly. Also used shock oil on the outside of the can, and some on the inside of the water jacket. I ended up damaging both of the o-rings on the water jacket.
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
