brian015
brian015's Avatar
02.19.2012, 07:52 AM
I've seen angle used like that in a few cars. TBH it does look a bit ghetto but it adds so much rigidity. Nice work Brian.
I was thinking of getting some of these baja wheel extenders. I was thinking to use the fronts, lop off the 12mm axle and dill out the centre to suit the lst axle. Do you think this would work?
That could work. Or you could use the rears with a 8mm id, 12mm od insert.
