brian015
brian015's Avatar
02.19.2012, 08:49 AM
That channel is kind of weird looking. I think I would have tried to find some way to shape the chasis a little bit to reduce the flexing instead of adding more parts to the setup? That exta aluminum just looks a little bit ghetto to me. Maybe just a piec of althread would not look so over bearing. Just another view or idea. Don't get me wrong we have to find what work for us, but I think I would have found another way. R&D is always a series of trials and tribulations. It is good to see that you have not given up on this.
While it may look ghetto at first glance, eventually I'm sure that you will realize that this u-channel (like the i-beam in construction) has both utility and a pleasing form.
I actually put a lot of thought into bracing this - as it is a long truck and I chose to use a flat chassis for this build - for the ease of layout. I don't have a mill, nor will I use any machine-shop services for this build, so changing the chassis was not an option.
I thought of different ways to bracing the length of the truck. Smaller braces front and back (like on truggies) would not work because it is too long. I thought of doing something down the center on the principle of the ue razorback - but the design was becoming too complex with the center diff and too much material would be used, in my opinion. In the end, the simplest solution seemed best - a top plate, which is all I have here. I couldn't use a flat top plate unless I attached it to the chassis at many points along its length - which I didn't really want to do. Finally, the u-channel is incredibly simple - just attach front and back - and has the extra usefulness of a place to route wiring. I'm still open to buying some different size u-channel (I looked at 1" x 1/8" with 1/2" legs - so lower profile) but this is what I had on hand and decided to try it out. I don't think it looks bad, and in the end, I am going to put a body on it, so we'll see - maybe I'll stick with this and maybe I'll try something else.
