Originally Posted by stampy
will a mip drive cup work on the pinion gear?
I am not sure which pinion gear you mean. If you referring to the stock emaxx yes if you have a emaxx mip drive cup. If you talking the hb diffs no cause they are a 8 mm shaft instead of 6mm. Tmaxx tranny drive cups are only a 5mm cup.
