Semi Pro
Semi Pro's Avatar
02.22.2012, 12:23 AM
And Patrick did say something about tweaking it so the efficiency doesn't "brick wall", which I would assume it means it can handle a higher rpm without effficiency falling as fast. Not sure how high I'd go personally - 8s seems a bit high.
i run the old one alot on 8s, im sure with proper care it would be fine
