lutach
lutach's Avatar
02.25.2012, 02:49 PM
Originally Posted by Jony Nitro View Post
Mm 14s what about a fan?
This is Kontronik we're talking about. The Jive ESCs for example, only needs a heat sink, but that's only for high amp usage. If the Kosmiks are built the same way the Jives are, than they will also only need a heat sink, but I doubt they will. Another example are the Jazz line of ESCs. I have a few and they are solid. I used an old 40A 32 cell version in my heavy truggy and it worked perfectly, but the small cap popped. Put the 55A 32 cell one in and it performed better then most higher amp ESC did. Also as with most Kontronik ESCs, their AMP rating is very conservative.
