Kcaz25
Kcaz25's Avatar
03.03.2012, 05:42 PM
Soon I will be no longer using the RPM truetracs on this truck and going to full FLM arms. The true tracs are great(I've never broken one) but they are too wide for my choice of CVD. And I don't want to remove the drive cups from my UE diffs and replace them with stubs. FLM Arms in the front has been awesome. No problems. and I will use beef Monster ball rod ends from Dubro on the linkage just like I have on the front for a couple years. I will still use plastic knuckles for now, as it is a good weak point for me. Even with the metal rings around the pivot balls on a big hit the knuckle will come off the balls rather than bend an a-arm or similar. This has only happened once.
I broke a screw off in my right FLM bulkhead. Does anyone have a spare right front bulk?
