Maxxman
03.11.2012, 12:43 PM
Originally Posted by A468BU View Post
The longest possible setup from the parts I have was using the stubs with the extended cups. They were longer than the supplied cups that came with the combo diff. What about the XXL Cvds. I have seen people using those with some mods to the carriers. I wonder if those are longer? Like i said if I take out the 8mm shims I used to shim the diff and shim the diffs between the housing and bearing with the bigger shim I should be able to use the stock axles for now. I am hoping atleast.
Ah, i see. I don't know about the XXL cvds i'm afraid. Yeah that should work for the stock axles, fingers crossed.
The savage cups, or any even longer, that i mentioned may add just enough length or you could ask Mike to make some of these for you but a few mm longer, http://www.rc-monster.com/proddetail...d=RCMdiffshaft
