auto2
03.15.2012, 02:21 PM
update- i ran at same track but only used whatever throttle the track could take. tried to have very little wheel spin. maybe 1/2 on the straight.
i got 17 minutes run time instead of 12.
motor was max temp of 150F on telemtry and was 125 in the pits by temp gun a minute later.
batterys were much cooler .100f
center dif was 50 degrees cooler.
60 degrees out today instead of 70
still a 150 amp current limit and a 3.5 voltage cut off
dont freek out with the rpm i may have 2 pole instead of 4 pole in telemrtry.? just devide by 2
