03.31.2006, 06:01 PM
thats for the truggy ratio. the buggy ratio will work but id like to run the helical cut truggy gears cause they should be stronger
for the buggy ratio i get
14.53 to 1 final ratio
and 49.61 mph this is with a 5.5" tire .25" for groth, emaxx locked in second with 51 20 gearing
as for the truggy diff, to match that ratio and speed i would need a 26 tooth pinion if every thing else stayed the same. thats a huge pinion :eek:
