03.19.2012, 12:36 PM
Cool, I'll have to order me one as well.
I'm using the eLogger V4 with with Wire Leads, 70 Volts, 150 Amps version. I also have the GPS module, one temp sensor that I barely use, brushless motor sensor,Servo Current Monitor that I have yet to use, and the Optical RPM Sensor For eLogger that I also never used.
I was going to use the optical sensor on the slipper clutch and then compare that to the motor rpm. Would make it easier to find the perfect current limiter setting.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
