Originally Posted by hooppjs
I'd recommend 500-700 size heli outrunner. I used one for awhile in my 1/8 Kyosho LM rally car. I also run the 600XL in a tunnel hull. My kv's were 1600 and 1650 on 4s.
Sounds tops.
http://www.wattsuprc.com.au/goods.php?id=1258
Thanks for the input. I used the speed calculator and it says a 1600kv motor is going to get me going like 60mph on 2s though... I am using the AX10 axle ratio which may be different from the Wraith ratio which I can not find out. Does anyone know what the Wraith axle ratio is?
