sikeston34m
sikeston34m's Avatar
03.21.2012, 08:13 PM
The 36/60 would be too small, that is a good buggy motor, IMO. The big wheels and tires will put too much load on it, plus i doubt this truck will be light.
The hybrid bulks use ofna or similar diffs.
Rpm arms and towers are a good idea, especially if you are using al bulks.
I think truggy front shocks would be the way to go, need something around 4 inches long if memory serves me correctly.
Slidell is fine, pissing down rain right now. Still working on all of my projects, save for rc...
I keep thinking about the entire "HV" craze when things stepped up to a massive 16.8 volts. LOL
Watts = amps x volts
Watts is the measure of total horsepower. It is Total Amp draw that makes or breaks a motors efficiency.
I want to try the 36-60 in this on 8S.
I remember this motor on 4S and it snapped 4 of the Traxxas Drive Shafts in about 8 runs. Alot of Torque.
I also remember running 2 - 4S 4000mah packs using a parallel adapter feeding a MMM Esc.
One day I accidently grabbed a series adapter.........the ESC armed and away we went.
Geared something silly, like 22/40, I seen the truck do a backflip at about 30mph when I grabbed WOT.
The setup survived. LOL Of course, I stopped the run, realizing what I had done.
