03.24.2012, 09:02 PM
Hey make sure your dremel has selectable speeds, mine has one speed- fast, and it cooks the plastic if left on the material for more than a very few seconds. It just leaves the plastic messy and melted. It moves the molten plastic around instead of removing it. It didn't end up being a terrible problem. I made-do and now have a very nice 8mm truetrac system that fully articulates in suspension.
I do now know that the Losi 8t 2.0 shafts will work on the front( or simply standard 3.3spec) suspension but will have to have spacers on the stub portion to take up the slack between the knuckle and the hex adapter. Even up to 4mm possible.
I may just leave the front with the TRX shafts that I already have which work great on standard suspension.
