rawfuls
roofles.
rawfuls's Avatar
03.27.2012, 11:19 PM
Originally Posted by wellby View Post
Try using a box cutter and back the cut with wood, should cut through pretty quickly
Kind of hard to find the perfect piece of wood to fit into the small box.
(here comes the jokes.)
But I think I just may saw one off one of our 2x4s and give that a try..
The cutoff wheels those kits come with are a joke, they shatter if you look at them the wrong way. The reinforced Dremel ones with the quick change mandrel are the best. Pick up one of them and put it in your drill chuck and give it a shot.
When using a cutoff wheel, slower speeds generally make the tool want to grab the work and jump around more. Higher speeds (to a certain point) generally slice right through instead of grabbing. Drill speeds were fine for my application, but for thin metal and/or fairly long cuts, a higher speed would help with control. All depends on the material and what kind of cuts.
Interesting.
How much are the reinforced Dremel wheels?
Which one would I want for aluminum (more specifically, thin aluminum?)
It will be very precise cuts, to give you an idea, I'm just cutting a hole for a small USB port, so it will have to be a pretty small blade?
