jayjay283
jayjay283's Avatar
03.30.2012, 10:29 PM
Differential Ratio: 3.142857142857143
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 19
Total Voltage: 14.80
Motor KV: 2700
Tire Diameter (inches): 3.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.004
Spur/Pinion Ratio: 2.68 : 1
Total Ratio: 8.43609 : 1
Tire Circumference (inches): 11.94 inches (303.23 mm)
Rollout: 1.42:1
Total Motor Speed: 39960 RPM
Vehicle Speed: 53.55 mph (86.02 km/h)
Effective KV Value: 2700
does that look right ? the diff it looks like on the nitro is 43-13 ? anyone know the specE ?
