Thomas Porfert
Thomas Porfert's Avatar
04.05.2012, 05:45 PM
The Traxxas drag car is the first setup to use the full capabilities of Castle Link Live. The technology was available and we were actually working with them on the drag car when the XO-1 was being finalized. (It has been a hard 2 months not letting it slip about the drag car) The reason for the RPM sensor on the XO-1 on the drive shaft is so they know if you try to change the gearing on a locked system. If their receiver sees a different RPM than expected and its still locked, it prevents you from accelerating further. The ESC knows the precise RPM of the motor because...it's actually driving the motor. I'm not sure why they chose not to implement the CLL protocol with the XO-1.
The CLL protocol allows nearly all settings to be adjusted remotely. The biggest problem we have is that we need the cooperation from other manufacturers to use their protocols to sync them with ours. So far it appears no one else is wanting to play ball. The CLL feature as been available for almost a year and half, the Traxxas setup is the first to utilize the feature.
