04.11.2012, 12:50 PM
I only have two buggy Tekin motors that I use(1400kv+1900kv). Owned the truggy motor once but never used it. The Tekin feels like a Neu motor, with a bit less power that is hardly noticable. The Novak is a smoother feeling motor over the Tekin, both being run with the Tekin Rx8 and sensor cable.
But you can't really compare the Novak too the Tekin, as they are different in rotor size and stator size to begin with. The Novak use bigger gangster Hall sensors. Novak can interchange stators, while the Tekin can't. Novak is easy to repair/rebuild, compared to the Tekin.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
