Mozzy
Mozzy's Avatar
04.30.2012, 02:32 AM
If you have high C rated batteries you should be able to change the 'start up power' to medium or high.
I use mine on high running 6S 4000mAh 40C. No problem at all. 1717 1580kv
I also have my timing set to high as well.
My temps don't get over 60 deg C on a hot day drifting around a 1/10 on-road track. This is on-off-on-off throttling too.
Maybe you need to email Mike about the slipping slipperential, cause, as far as I'm aware, they should work properly for any application.
Has anyone else suffered a slipperential failure?
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
