mothman
05.08.2012, 07:20 PM
I guess your only option is to buy the outdrive from FLM. Dont see any other option since the ball size of the dogbone is 11mm..
Originally Posted by FG101C View Post
Has anybody else used this setup from Fastlane? http://www.fastlanemachine.net/prodd...iew=all&cat=22
My question is about the outdrives pictured, what else works? The Heavy duty Flux outdrives wont work because of the way the bulks go together, the holes are too small for the Flux HD outdrives. It appears the one's pictured are the only one's that will work, the problem is they break where the little pin goes in to drive the sun gears.
Is there an alternative?
Thanks.
