ziggy12345
05.14.2012, 03:48 PM
Ive been running the 25063 x series with Lehner 3040/6. Its a bit of a miss match as the motor cant handle the volts of the esc and the ESC cant deliver the amps the motor can handle but I cant fault the ESC. I use it with 2 x 6s packs and get a constant 240 amps no problems. The MGM has some great feaures like throttle ramp timing up to 1 minute. Amp peak cut off, peak motor rev cut off, data logging etc...
Cheers
