millzee
millzee's Avatar
05.20.2012, 06:42 AM
The day I received the roller I stripped out the traxxas plastic's and re-fitted with a aluminium servo mount, hitec 7955 servo, neu 1527 and a mamba monster speedo with external castle BEC. This set up ran well enough to end my 4 hour driving session with a cold tire 75mph "super" crash that was my PB for cartwheels by both number and speed resulting only with a broken rear lower a-arm, front splitter and plenty of scratches on the stock body. This was a nice lesson to learn early on......, I can't drive. I am happy to run 6s and gear it with a 25t pinion and 50t spur, 75% punch control, throttle curve and plenty of brake, this is a good fun set up that can still get you in heaps of trouble if your heavy on the trigger, I'm finding that if you drive like a dick, it'll cost you just as it would with a real sport's car, only on a scale ratio.
After the crash the carbon chassis and a couple of goodies arrived so it was build time anyway. I've found myself hopping up everything I buy, sometime before I've driven the model, this time I'm only going to up-grade things as needed. On the list so far is the A-arms, way to brittle (for my poor driving).
The first thing I needed was a safe home for the battery. I used a cabon fiber battery tray and made a side plate out of 2mm c/f sheet. The side plate act's as both a battery support and protection from the drive shaft and shaft support bearings. The tray is raised by c/f blocks so I can get the velcro straps under and around the battery and sticky back 5mm rubber foam added between the c/f and battery. The velcro strap's needed to be longer so I joined 2 by applying ca glue on the velcro's "hook" side, locking the velcro closed and then stitching with 80lb braid to reinforce it.
