millzee
millzee's Avatar
05.20.2012, 07:23 AM
I played around with the shock mount's a little to gain some ride height but I think I'll need to re-adjust the front end as it's riding a little high. The white springs lasted about 3 minutes until I had them srewed so far down I figured I may as well put the red(green mark) springs back, a lot firmer.
I did my best to keep the weight dispersed evenly in both length and width, the battery forward of the motor along with the 2x 2500mah 3s LED batteries up front counteracts the weight of the motor side. The COG is just forward of center so the front wheel's stay on the ground a little better.
I was also able to keep the weight low with this set up, the 1717 add's weight at a higher point.
I have received a few set's of wheel's, ofna rim's in bright yellow for night and chrome for day with taped PL road rage tire's and extra mod firm rear foam's and firm front foams, I'm not sure how they'll go but if they last a few night's they'll be good for ripping around the street's, I'll keep you posted.
