zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.21.2012, 11:12 AM
Pack IR is actually the only story as far as performance goes... chargers might not be the most accurate when it comes to calculating pack IR to begin with. The Turnigy pack is literally dumping out on you early, which would give a false calculation on the current draw you are using, what kind of temps are you getting? What is your LVC set to?
Also, what are these 5000's you mentioned?
