maxxdude1234
maxxdude1234's Avatar
04.02.2006, 12:04 PM
Originally Posted by GriffinRU
So, to correct these statements I start my posts. Bottom line - 8L and 8XL cannot produce the same power at given voltage because they have different Kv number based on motor construction.
Apart from this statement, I fully agree with you last post. The 8L and 8XL can produce the same power at a given voltage, if they are both geared to achieve the same speed. However, if they are both geared optimally, then they will achieve different speeds and hence have different power output
