04.02.2006, 06:31 PM
I guess the question is, do you want to wait for TP to get thier software together for 3c...
I'm also curious if anyone has used the Li-saver with the 9920 esc? The other issue is increasing your pack weight, by going with the 3700mah packs, will degrade your trucks performance.
MetalMan, what upgrades are you refering to exactly? If its an upgrade in mah config's, you'll be increasing your weight which isn't ideal for racing. The reason I suggest FMA is they have every feature, I see, needed for racing available right now.
Ha Ha
