04.03.2006, 07:13 AM
Well, it's not really a problem, CHC. It just shows the batteries are not up to the task. A 2P setup will cure this. And if I have the throttle at 75%, it works fine even on a 1P setup (altough, admittedly, the Lipos suffer a bit) Just for the record :)
More testing is neede here. Be on the lookout for a detailed thread!
Gustav, a 1:11 reduction on a heavy MT will pull some serious amps. Might drop your voltage so the LVC cuts in.
Just check without the LVC and we'll know more.
