Gustav
Gustav's Avatar
04.03.2006, 09:53 AM
Only got the one pair of packs at the moment so unfortunately not. It will do it on 16 cells too but only with the wheels off the ground,runs OK on 16 cells at full throttle even on a high gearing,it seems more like a certain motor rpm where it happens rather than current draw.
Could a bad solder joint cause this syptom in your opinion,i might re do the wiring tonight.
