Cain
06.24.2012, 02:13 PM
he mentioned that, but the prices... oh the prices lol. I am kind of still debating 3mm 7075 versus the 4mm for the weight savings, but quite a bit difference in price.
I will definitely report back on the bearing. I am thinking that if I am looking at it right, basically the spacer pushes up against the inner "ring" on the bearing so it doesn't push up against the part where the balls in the bearings are, locking itup (that little lip on the bigger one).
I am hopeful that with these bearings, maybe since they are bearings and not just spacers, it will be a non issue as they will allow the axle to rotate inside them?
again,my understanding could be way off for sure. But, the cost of the bearings if I recal l correctly is like only $1.75 shipped per bearing. worth trying out on 1 axle to see if it spins freely.
By the way,those wheels and tires you are using, is it possible to get them in the states? If so, have you seen them on ebay? what is there name and model number exactly?
