Gustav
Gustav's Avatar
04.03.2006, 12:50 PM
Originally Posted by nl12
Maybe you have a different kv motor than you think and it is hitting the 42000, maybe lehner mismarked the motor, stranger things have happened. Try the motor with a different controler like a 9920 unloaded and see if it does the same thing, if it does then something is definately wrong with the motor, if it works fine--maybe its your controler, maybe it is the mismarked kv issue. I dont know how to test the kv of a motor if anyone does that could help eliminate one potential problem.
Good idea about the mismarked motor but it can't be the 42K limit because it happens at 32.1mph(GPS) on 12.6:1 gearing which is less than 30K rpm i think.It will repeatably hit almost exactly that speed before it happens.
