zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.01.2012, 05:21 PM
I could only see the pack having slightly more surface area to dissipate heat, and even this I am not sure of.
The only discharge test I have seen coming close to its max continuous rating was Everydayflyer on RCGroups testing the 3s 45C 2200mah Hyperion pack, at 42C continuous discharge the voltage is well acceptable, plus the pack temp is at a still safe ~140F.
Everydayflyer has NEVER tested a Maxamps pack (from the list I saw), and probably never will as maxamps KNOWS that it will simply not return a remotely acceptable discharge graph, let alone for it's ratings.
