nitrostarter
nitrostarter's Avatar
07.04.2012, 02:26 PM
1717 uses the same mounting pattern as the 2200. It just have a larger diameter can. So if you have space underneath your motor it should work. If not you could raise the whole center diff with a spacer or similar to give you the additional clearance needed.
N. Rustler conversion
