07.13.2012, 11:34 AM
Well no it's not, I have 100k traxxas diff fluid, and I am not sure how it compares to the typical 1 - 10k rating of the brand you are mentioning. I know that there are a few different ones.
100k is 100k, doesn't matter which brand it is really in that sense- if you need 3k or 5k, then buy 3k or 5k of whichever brand takes your fancy. 100k of traxxas oil doesn't equal 10k of brand X oil- the ratings are consistent in that sense across brands ( allowing for different formulas ) as far as I'm aware...
I just noticed that the diffs I bought do NOT come with pinion gears. I just looked it up on AMAIN, I found this gear, which all I need for this is Mike's Revo shaft adapter, right?
http://www.amainhobbies.com/product_...al-Pinion-Gear
Yep, that's the one you want- don't forget to add some shims though ( something like 8x10x0.2mm will do the trick usually ).
