07.22.2012, 11:23 AM
I haven't seen the parts you are talking about, so I might be thinking of this wrongly, but what about a sleeve, 6mm ID 8mm OD to go over the stock 6mm shaft? Kind of like Mikes pinion adapters to use larger bore pinions on smaller shaft motors.
