maxxdude1234
maxxdude1234's Avatar
04.04.2006, 08:58 AM
Most people run larger motors at a lower rpm and 'gear up' to take advantage of the torque. Unfortunately, most companies only issue info on the kv of motors and not the kt. Ideally you should aim to keep you motor in the 35,000-40,000rpm mark. What application are you using your motor in?
