Thread: F1
nativepaul
nativepaul's Avatar
09.07.2012, 07:53 AM
If the height of the nose is the only problem I can easily fab something to fix that, I'm wanting the modern (but not this year's) look so would be raising it anyway, maybe using the 3racing wing as mine doesn't have any of the endplate elements modern ones have, or fab up some mods for mine.
I have to buy all my parts on Ebay, unfortunately you have to but they are not inflated prices for rarity yet so that is fine by me, tyres are the main thing the best aftermarket tyres seem to be drying up, I may have to resort to using tamiya ones again at some point and they are not as grippy. My gearbox has held up well so far all stock, I upgraded my diffs to the lightweight ones, as a preventative measure while my originals were still good, most of my mods are to the suspension, if you want working suspension rather than it being a pan car like all the rest I recommend removal of the white glass spring at the bottom of the front suspension which allows it to work at the front, and upgrading to heavyweight A arms, metal bellcranks and Oringing all the balljoints allows the shocks to actually do there job rather than flex/slop soaking up the movement before it gets to them, I also fitted a 3racing carbon chassis and alloy motor mount but quite frankly its just a bit of bling, though it saves weight it is hardly any stiffer than the stock tub and didn't effect the handling.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
