09.14.2012, 10:04 AM
2 will work as you are creating a reference ground between the batteries.
I dont really like it though as its going from battery -> esc -> rx -> bec -> battery.
Also by only having the BEC across a single battery you will be always drawing extra power from a single pack and puting the packs out of balance which just means more time on the balancer or worst case you will mess up your voltage cut off.
