09.22.2012, 03:39 PM
Looks good so far! That line does still have a very sweet spot not only here but all through the rc community.
If that was my truck..
1. Upgrade MMP to a larger esc due to sheer weight of the truck or at least use an external BEC
2. Find out for the owner of RCM, Mike if he is still making the hybrid bulks for this truck. It uses 1/8 gears and make a bomb proof diff set up.
3. Ditch the 8 shocks for 4. Stock shocks are not that good and will leak shortly. Find a bigger bore that will fit...much simpler
4. Mono block as you mentioned....they pop up from time to time on the UE site so check their often
5. AL towers for strength
6. AL carriers maybe
Other than that it is purely cosmetic stuff and how much bling and $ you want to drop into it.
