override
override's Avatar
10.12.2012, 03:05 PM
This is an issue that some have ran into...I did not but I do remember there were some chassis's that were incorrectly made a long time ago.
When I built mine I used an aluminum 2.5 transmission with RRP gears and the RRP slipper clutch. I don't know how fitment is with the 3.3 as I have never tried but there are a few things you can do to solve the issue.
1. You can use the 2.5 tranny and if you want you can get the 3.3 upgraded slipper shaft so you can use the new style slipper.
2. Check out MIP and grab some of there 3.3 shafts, I used there shafts and they hold up really well. For the front shaft you can chop off some material from the splined ends to shorten them. Don't go to far or you will not have any spline left to bit the other half.
3. RC4WD makes several splined shafts (Punisher shafts) at various sizes and most all the ends are compatible with one another.
