zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.16.2012, 02:15 PM
All IR checks done with 720i NET charger, BULK discharges done with MIXED 720i 10amp discharge, or 13C wire constant resistance discharge, a few heavy discharges of 30C or more.
Dschg#1 - 4300mah IR check: 3mOhm
Dschg#60 - 4315mah IR check: 2mOhm
Dschg#110 - 4350mah IR check: 2mOhm
Dschg#130 - 4340mah IR check: 2mOhm
DSCHG # 131.....
Discharge load 16FT of 6awg booster cable shorted
Cell temp before & after: 111F - 138F
Cell voltage before: 3.425v. fully charged
Cell voltage on load: 3.053v.
Total discharge time: 2:04 mins = 30+ C discharge = 132amps AVERAGE DISCHARGE
Discharge rate would be higher than 30C at start of discharge, and lower at end of discharge.
