04.04.2006, 07:25 PM
Will the stock revo shafts fit a emaxx?
CHC, I'm not familiar with an e-maxx driveshaft placement and clearance, but the Revo driveshafts telescope so there is some leeway as far as length goes. The fronts are a lot shorter because of the disc brake mechanism, but you may be able to mix and match the rear and front parts to get the length you need. The Revo shafts are larger in diameter though, so if the stock maxx driveshafts are a close fit, then the Revo shafts won't fit.
