knuckle
11.20.2012, 07:13 PM
Thanks my question is though, if my servo does 7.4 volts, and you said the Castle BEC in the link, which I have only does 6v max?
The link says it does more.
djustable Output Voltage
4.8V to 9 volts.
So if my servo handles 7.4V, I use the castle link to set the BEC to 7.4 correct? I don't need to disable the BEC on the ESC either right? There's no power going out of it anyhow to the receiver.
I did get a Spectrum radio system, which has a receiver that can handle the higher voltage.
