nativepaul
nativepaul's Avatar
11.24.2012, 01:10 AM
No, it wont stop it from going too many RPM only keeping it at partial throttle or using lower voltage will do that.
Personally I wouldn't put it in anything bigger than an 1:8 buggy or 1:10 sct, but if it is only a spare for a bigger flux, it will likely never get used, and if it does it only needs to hold up for a few months while you get the other one repaired.
Do you have 1 6s pack or 2x 3 s packs? if you have 2x 3s you could wire them in parallel instead of series to use the 2650 safely instead of gearing down, saving a few bucks and you wouldn't have to worry about it going too many RPM.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
