11.29.2012, 04:59 PM
Originally Posted by agw View Post
Yes, I saw those as well but I have to say, just got back from trying out the Sweep Slick 55 and I had a blast. No ESC overheating, a good degree of drifting until they warmed up a bit, much easier to drive.
Meanwhile I lost a wheel because the nuts are not right and the nylon part does not reach so they come loose easily. I'm waiting for the HPI nuts and hopefully they'll work better otherwise I'll need different CVDs.
I took an on board video which I'm hoping to find the time to edit.
You can spin those nuts and put the nylon part on first. If it's a flanged nut just use a washer for the flange. Also, loctite is your friend
