Mozzy
Mozzy's Avatar
12.27.2012, 10:27 AM
Originally Posted by Robl45 View Post
I just wanted to confirm that it would also fit a motor as small as 36mm.
Here are a few pics of mine.
I managed a very simple cheap conversion. Then I bought the Losi Single Speed Conversion, which needs longer bolts to hold the gear & put nuts on the exposed threaded end. I had mine fall off. With nuts, no problem!
Now running a 34T pinion. This motor is the 1717 1580kv Castle motor, Castle Mamba Monster on 6S. The closest thing to it now is the XO-1 motor.
Also, I changed to motor brakes because I could not get it to stop or stop chewing through brake pads & discs. They would glow red in the night time!!
A little video on the beach with paddles.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
