Mozzy
Mozzy's Avatar
12.30.2012, 06:33 PM
I had a really bad experience with FD years ago & I would never recommend them for anything, because, their designs certainly aren't fine!!
I have my battery mounted exactly where the tank used to be & wheelies can be controlled quite easily by lowering the suspension. Mine is mostly used for speed runs anyway, so, being lower is much better for me.
I agree with overdriven on the possible damage too. Pull your diffs & check them & while you're at it get the TiNi crown & pinion gears for your diffs, they will last longer.
I have heard of people using metal diffcasings too with great results, but, I never bothered & have had no troubles so far......touch wood!
Good luck with it & keep us posted.....give us some pics!!
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
