Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
01.05.2013, 10:30 PM
Originally Posted by x-y View Post
the car with more steering is whitout any doubt the s8bxr ...... use an amazing knuckles system and the "exterior" tyre have the same steering angle than the interior tyre .... is awesome to see
http://www.modellismo.net/mercatino/data/8/0432.JPG
the mbx6 is the faster car I had and also very strong ...... I recommend buy mbx6 or mbx7 ....
Actually, in terms of front end grip you WANT Ackerman geometry and not Anti-Ackerman or "Parallel Geometry". Perfect Parallel geometry for steering isn't actually all that desirable because as the weight transfers to the outside it requires a greater slip angle on the inside tire to achieve the same level of grip. So you WANT the inside tire to turn more in most cases. This is especially true in tight corners when you are using alot of steering input.
In a high speed sweeper for say an on-road car less ackerman angle is better because the actual turning radius is much less and the tire scrub is much worse. Its a case of turn by turn.
This link has pictures that explain perfectly why Parallel or Anti-ackerman is not desirable in all situations. Once you see the animations you'll understand why you want that inside tire to turn more in most situations.
http://www.rctek.com/technical/handl...principle.html
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
