Pdelcast
Pdelcast's Avatar
01.11.2013, 07:37 PM
Originally Posted by TheMonster View Post
hello Patrick,
I install 1.39 and went on test drive...
the cutoff act strange...batteries were 3.8V per cell (4S) and the cutoff already start to slow the car...
so I programmed the ESC again and turnd off Lipo cutoff.
then I had more power but still have those problems from 1.38:
1. The car lost power, and Punch ... acting very strange and took a long time to accelerate. The car did not have Punch power.
2. stuttered The vehicle .. like the Cut Off is approaching (batteries were charged).... didn't happened becose I turnd off the cutoff
3. Random vehicle brakes every 30 seconds or so -now only break when I drive in high speed and then pot the trigger back to neutral, and when the car is still moving press the trigger again...the sometimes the car put itself into break...and the I cant controlled it for 3 seconds.. like lost signal..
4. The motor started making strange noises and sounds like it opposes itself...only make those strange noises when the car is acting like in 3 (when it break)
5. The ESC stopped to get a response from the remote for a few seconds every minute or so ... (after 2-4 seconds I managed to control it again)
can you help to get a stable version on my esc ? not a beta ...
I really appreciate your help !
Sorry man,
It sounds like there is an problem with that controller -- we tried 1.38 and 1.39 here, and had no issues.
If you send me your info, I can have tech support send you a replacment controller on Monday.
Thanks!
Patrick
Patrick del Castillo
President, Principle Engineer
