01.12.2013, 05:13 AM
hey,
I will try to go back to 1.24 and see if it fix my problems. I will update you in a short time.
I calibrate my esc every time after program it. and also tryed to bind the remote..dident work, so I tried a diffident remote and receiver from my friend but it didn't fix the problems..
its the ESC...
I will try 1.24 now and see if it fix my problems.
thank you !
UPDATE:
I switch back to 1.24, first run with charged battery...
1. The car lost power, and Punch ... acting very strange and took a long time to accelerate. The car did not have Punch power.
2. stuttered The vehicle .. like the Cut Off is approaching (batteries were charged).... didn't happened because I turned off the cutoff -that problem hasnt fix with 1.24 :(
3. Random vehicle brakes every 30 seconds or so -now only break when I drive in high speed and then pot the trigger back to neutral, and when the car is still moving press the trigger again...the sometimes the car put itself into break...and the I cant controlled it for 3 seconds.. like lost signal..
4. The motor started making strange noises and sounds like it opposes itself... make those strange noises when the car is acting like in 3 (when it break)
5. The ESC stopped to get a response from the remote for a few seconds every minute or so ... (after 2-4 seconds I managed to control it again)
same problems...I don't know what do to anymore...
Patrick, do you have anther idea how to fix this problem ? what am I supposed to do now ???
thank you !
